[L760] Tuto installation de jeux
  • Please log in to reply
64 replies to this topic
#1 garouk
garouk
  • 48 Messages :
  • Modèle:L760
Posté 05 octobre 2007 - 13:34
Bonjour a tous.
Je pense faire plaisir a beaucoup de monde en disant que ce tuto va vous permettre d installer des jeux pour le L760.
Je vous copie le texte (en anglais) avec les infos pour l installer :
First you need the “Qualcomm USB” drivers and “BitPim”. Prepare the USB cable, but dont put it in!
Driver: www.rexnet.it/firmware/utility/qualcomm_usb_driver.zip (changed from the original coz it didnt work for me)
BitPim: http://sourceforge.net/projects/bitpim
a. Unpack the drivers to a folder (exp. Desktop), but don’t install it!
b. Install BitPim.
1. You must entering follow code into the phone: *#0523#
2. [9] common >> [6] USB Configuration >> [2] Qualcomm USB [*]
--> Qualcomm USB Configured.
Plz Reconnect the Cable.0
3. Now put the USB cable in the phone and Pc.
--> Windows found a new hardware.
Install the hardware manual and chose the Qualcommdriver folder.
Now go to the Hardware manger ->Modems->Qualcomm, you must know the port number.
4. Open “BitPim” and configure the software for your u700.
Phone type: Other CDMA phone
Com port: *look at step 5*(you can Browse, but chose the right one!)
And press “OK”
5. Start “BitPim”, go to the menu “View” and active “View Filesystem”.
6. Klick on “Filesystem” (left in BitPim).
Now can you see a blue folder, open the folder (press on “+”).
--> … retrieving
7. Now put the games (jar and jad files) in the follow folder “Games” (Media->Games).
8. Disconnect the USB cable from the phone.
9. Leave the Qualcomm menu and entering this code in your L760: *#6984125*#
Now are you in “Admin setting” menu.
a. Select the menu [4] Internals (Master Key: *#9072641*#)
b. Chose the menu [7] Storage settings
c. Update media database, Update Java DB and Create AX Dat File.
That it’s!! (You can leave “Admin setting”.)
Important: DON’T delete the games with the mobile phone, you must delete the games with “BitPim”.
Source : http://forums.hardwarezone.com
[Edité par Caelle : Original desciption in german by "DerRichter", samsung-stuff.de, translation by tariq_ch.]
Voila!!J espère que ca vous aura aidez.
P.S: J'ai testé ca marche sans pb
Ce message a été modifié par Caelle - 08 octobre 2007 - 11:58.
#2 Caelle
Caelle
    L'EphéMère
  • 13 177 Messages :
  • Sexe:Féminin
  • Modèle:G Nexus
Posté 05 octobre 2007 - 13:37
Peut être qu'il y a une source à citer non? :phone1:
#3 sodef_77
sodef_77
  • 15 Messages :
  • Modèle:L760V
Posté 06 octobre 2007 - 09:52
taurais pas le tuto pour le flasher aussi stp
SFR Forfait essentiel 1h illimiter mms\texto et appel 24\24 7\7
#4 garouk
garouk
  • 48 Messages :
  • Modèle:L760
Posté 06 octobre 2007 - 10:02
Non dsl!J ai cherché sur le net!C est introuvable!Je pense qu il va falloir être patient...
Par contre j ai trouvé un logiciel qui permet d explorer le téléphone (database, media...)
Ce logiciel s appelle BITPIM.Si qqun est douée en téléphonie mobile, je pense que c'est possible de pouvoir le flasher...
#5 Caelle
Caelle
    L'EphéMère
  • 13 177 Messages :
  • Sexe:Féminin
  • Modèle:G Nexus
Posté 06 octobre 2007 - 11:16
Peut être qu'il y a une source à citer non? :glurps:
#6 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 08 octobre 2007 - 00:37
est cela marche pour le l760v?
#7 garouk
garouk
  • 48 Messages :
  • Modèle:L760
Posté 08 octobre 2007 - 10:03
Oui ca marche pour le L760V.Il faut juste que tu rentre ces codes la plutot :
Vodafone Firmware Codes:
Admin Pass : *#3695147*#
Internal Pass (Master Key) : *#3971258*#
#8 sodef_77
sodef_77
  • 15 Messages :
  • Modèle:L760V
Posté 08 octobre 2007 - 11:49
ah ok
#9 garouk
garouk
  • 48 Messages :
  • Modèle:L760
Posté 08 octobre 2007 - 11:58
Désolé, mais je ne l ai pas pris sur un site internet.C est pour ca que je n ai pas mis de source :hug:
#10 Caelle
Caelle
    L'EphéMère
  • 13 177 Messages :
  • Sexe:Féminin
  • Modèle:G Nexus
Posté 08 octobre 2007 - 11:59
edit: bon je vais y arriver...
La source que tu as mis ne l'est pas :hug:
je viens d'editer on post.
Même si l'info n'est pas issu d'un site à proprement parlé, il faut quand même citer la source :)
Ce message a été modifié par Caelle - 08 octobre 2007 - 12:02.
#11 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 08 octobre 2007 - 22:10
merci ca marche nikel au fait vous n'avez pas des sites pour telecharger des jeux pour portables?
#12 garouk
garouk
  • 48 Messages :
  • Modèle:L760
Posté 09 octobre 2007 - 09:56
Fait une recherche sur le site et cherche des jeux 176x220!!
Tu en trouvera plein :mdr:
#13 coincoin94
coincoin94
  • 5 Messages :
  • Modèle:sgh l760v
Posté 10 octobre 2007 - 20:12
bonjour,
moi aussi j'ai le SGH-L760V
et j ai suivi le tuto mais je block a l'etape 9:
"9. Leave the Qualcomm menu and entering this code in your L760: *#6984125*#
Now are you in “Admin setting” menu."
il me dit donné eronée...
a l étape 7 :
"7. Now put the games (jar and jad files) in the follow folder “Games” (Media->Games)."
j ai mit les fichier jar et jad dans le dossier patpouf (Media->Games->patpouf)
es que ca peu provenir de la?
#14 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 11 octobre 2007 - 23:37
c'est parceque les codes sont differents selon si tu as le L760V oule L760 pour le L760V c'est:
apres tu suis les memes étapes
#15 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 12 octobre 2007 - 00:02
pour plus d'info clique sur le lien il y a des photos pour chaque étape c'est la méthode du u700
Le lien
#16 coincoin94
coincoin94
  • 5 Messages :
  • Modèle:sgh l760v
Posté 12 octobre 2007 - 17:11
merci beaucoup ca marche ^^
#17 asticot
asticot
  • 78 Messages :
Posté 21 octobre 2007 - 20:49
Bonjour
Y a t'il une traduction en francais du tuto svp
#18 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 23 octobre 2007 - 22:14
j'aimerais ajouter un petit quelque chose c'est ce site de jeu pour telephone il sont pratiquement tous compatibles l760v vous trouverez des jeux du genre PES2008 fast and furious fugitive driverchampionship manager 2007 real rugby... en fait allez voir vous serez pas decu il y a aussi un petit plus c'est gratuit :cry:
#19 Mehdino13090
Mehdino13090
  • 14 Messages :
  • Modèle:l760v
Posté 23 octobre 2007 - 22:21
vous aurez juste besoin de JADmaker et du début de ce tuto
#20 Vaan38
Vaan38
  • 7 Messages :
  • Modèle:SGH-L760V
Posté 25 novembre 2007 - 13:51
Salut les amis.
J'ai des copies de sauvegardes des jeux suivants:
Block Breaker Deluxe (Jeu en Anglais)
Brain Challenge
Bubble Bash
Dogz
Freestyle Motocross
Gangstar - Crime City
Metal_Slug_MI
Meteos - Astro Blocks
Midnight Casino
Midnight Poker
Platinum Solitaire
Rayman Kart
Real Football Manager Edition
Scarlottis Mafia Wars 2
Sonic The HedgeHog
Tropical Madness
Worms 2 (Fonctionnel mais un peu lent)
Zoo Tycoon 2
Zuma
A bon entendeur...
Loïc
(Si quelqu'un a PES 2008 et Real Rugby totalement fonctionnel pour le L760V, qu'il me fasse signe.)
MERCI BEAUCOUP
