[Nokia] Review & Test N73
97 réponses à ce sujet
#1 Anakronik
Anakronik
  • 11143 messages
  • Modèle:S60 User
Posté 10 Aug 2006 - 23:29
Test du Nokia Nserie N73
Cliquer pour agrandir
Bonsoir :)
Caractéristiques générales:
Quote long :: Utiliser la barre de défilement vertical pour accéder à l'intégralité du contenu
General
Dimensions
  • Weight: 116 g
  • Height: 110 mm
  • Width: 49 mm
  • Thickness (max): 19 mm
Operating frequency
  • Dualmode WCDMA/GSM and quadband GSM coverage on up to five continents (WCDMA2100/EGSM850/900/1800/1900 networks)
  • Automatic switching between bands and modes
Memory Functions
  • Up to 42 MB* internal dynamic memory for contacts, text messages, multimedia messages, ringing tones, images, video clips, calendar notes, to-do list and applications
  • Support for miniSD memory card (hot swappable)
  • Approx. memory capacity indication with 1GB miniSD memory card
  • Video (MPEG4 CIF @ 15fps AAC audio) up to 175 min
  • Photos (3.2 megapixel) up to 1219 photos
  • Music (eAAC+) up to 1092 tracks
* Changes to product details are possible without prior notice. Application offering may vary. Dynamic memory means that the available memory is shared between dynamic memory functions. When any of these functions is used, there is less available memory for other functions which are also dependent on dynamic memory.
Display and User Interface
  • Active standby main services always on top
  • Active toolbar interface in camera and gallery
  • On device photo editor and video editor (manual & automatic)
  • Large bright 2.4 inch QVGA (240 x 320 pixels) TFT color display with up to 262,144 colors
  • Ambient light detector - used to optimize display brightness and power consumption
  • Review key provides direct access to photos and videos
  • Multimedia key provides direct access to predefined application
  • Slideshow from gallery with Ken Burns effect (automatic zoom and pan) and 3D sound effect stereo speakers
  • S60 software on Symbian OS
Call Management
  • Speed dialing
  • Voice dialling and commands
  • Nokia PoC (push to talk)
  • Contacts: advanced contacts database with support for multiple device and email details per entry, also supports thumbnail pictures and groups
  • Call logs: keeps lists of your dialed, received, and missed calls
  • Automatic redial
  • Automatic answer (works with compatible headset or car kit only)
  • Supports fixed dialing number, which allows calls only to predefined numbers
  • Conference call
See New - Mobile Photography and Video
Camera Specifications
  • CMOS sensor, 3.2 megapixel (2048x1536 pixels) with autofocus and digital zoom up to 20x
  • Carl Zeiss Optics, Tessar™ lens
  • Focal length 5.6 mm
  • Focus range 10 cm ~ infinity
  • Macro mode with 10 cm focus distance
  • Mechanical shutter with 1/1000~2s shutter speed
  • Active slide cover for lens protection
Photography
  • 3.2 megapixel camera (2048 x 1536 pixels) with up to 20x digital zoom
  • 2-stage capture key for autofocus control
  • 2.4 inch camera viewfinder in landscape orientation and with active toolbar
  • Slide for camera protection and activation
  • Integrated flash (operating range up to 1m)
  • Modes: auto, off, on, red-eye reduction
  • Advanced camera modes: still, sequence, video
  • Scenes: automatic, user defined, close-up, portrait, landscape, sport and night
  • White balance: automatic, daylight, cloudy, tungsten, fluorescent
  • Color tone: normal, sepia, B&W, vivid, negative
  • Light sensitivity: high, medium, low, automatic
  • Settings for brightness adjustment, image quality, self-timer, white balance and color tones
Video
  • Video: play, record, stream
  • Audio recording AAC stereo
  • Video stabilization
  • Video clip up to 1.5h (limited by available memory)
  • File format .mp4 (high), .3gp (normal, MMS)
  • Video capture: 352x288 (CIF) at up to 15 fps MPEG-4
  • Automatic white balance control
  • Scenes: auto, night, close-up, snow/beach, cine, old film
  • Digital zoom CIF up to 4x / QCIF up to 8x
  • Two-way video call capability
  • Second VGA camera (640 x 480 pixels ) with up to 2x digital zoom
  • Real time video sharing to another compatible mobile device
Editing
  • On device photo editor and video editors (manual & automatic)
  • Home photo editing on compatible PC with Adobe Photoshop Album Starter Edition
Nokia XpressPrint
  • Print digital photos directly from the device
  • Transfer photos directly to a compatible printer, printing kiosk via Bluetooth wireless technology, a compatible miniSD card or to PictBridge-compliant printer via USB cable
  • Built-in application is quick and easy to use; no installation, no fuss
  • Print tag tag photos for later and easy printing
  • Photo quality prints up to 10x8/25x20cm
  • Find out more at www.nokia.com/xpressprint
Nokia XpressShare
  • Easy sharing of captured photos and videos directly from the gallery or straight after capture via email or Bluetooth wireless technology while retaining full image quality or via MMS with automatic resizing of images to fit MMS
  • Video sharing for one-way live video or video clip sharing within the voice call
  • Image/video uploading from gallery to pre-defined online album
  • Find out more at www.nokia.com/xpressshare
Nokia XpressTransfer
  • Transfer and organise photos and videos between your device and compatible PC
  • Connect to compatible PC and images are automatically transferred with Nokia Image Store feature in Nokia PC Suite, and photo albums created on the device are saved in similar albums on the PC
  • Organise and edit photos and videos on a compatible PC with Adobe Photoshop Album Starter Edition
  • Deletion or resizing of the images and videos transferred from the device. Resizing means you can carry a large collection of photos and videos on your device and full quality versions are stored on the PC
  • Gallery preserves a view of photos and videos transferred to PC
  • Find out more at www.nokia.com/xpresstransfer
Hear New - Mobile Music
Music Features
  • Digital music player: supports MP3/AAC/eAAC/eAAC+/WMA with playlists and equalizer
  • OMA DRM 2.0 support for music files
  • Stereo FM radio (87.5-108MHz /76-90MHz)*
  • Visual Radio support, find out more at www.visualradio.com
  • Integrated stereo speakers with stereo music
  • Nokia Music Manager application in Nokia PC Suite for music transfer
*Stereo sound can only be heard with a compatible stereo headset.
Do New - Mobile Computing and Connectivity
Productivity
  • Quickoffice document viewers (Quickword, Quickpoint, Quicksheet)
  • Adobe PDF reader
  • PIM (Personal Information Management): Contacts, Calendar, To-do, Notes, Recorder, Calculator, Clock, Converter, Printing
  • PC synchronization with Nokia PC Suite - Local/Remote (Windows 2000, XP)
  • Data: Calendar, Contacts, To-do, Notes, Email
  • PC applications: Microsoft Outlook (2000, 2002, 2003), Outlook Express, Lotus Organizer (5.0, 6.0), Lotus Notes (5.0, 6.0)
  • Anti-virus
  • Yahoo! Go
  • Email client with attachments and mobile VPN support
  • Settings Wizard/Access Point Configurator
Browsing & Messaging
  • Internet browser: XHTML, HTML
  • Email (SMTP, IMAP4, POP3), MMS, SMS
Connectivity
  • Pop-Port ™ interface with USB 2.0 full speed
  • Bluetooth wireless technology 2.0
  • Infrared
Data Transfer*
  • WCDMA 2100 with simultaneous voice and packet data (PS max speed UL/DL= 128/384kbps, CS max speed 64kpbs)
  • Dual Transfer Mode (DTM) support for simultaneous voice and packet data connection in GSM/EDGE networks
  • WCDMA packet data rates: UL 384kbps, DL 384kbps
  • Circuit data to 64kbits/s for video call
  • EGPR class B, multi slot class 11 (UL 118.4 kbps, DL 236.8 kbps)
  • Speech codecs supported: FR, EFR, WCDMA, and GSM AMR
  • Data transfer application for moving data from compatible old Nokia S60 device over Bluetooth connectivity
*Actual achieved speeds may vary depending on network support.
Add-on Software
  • Operating system: Symbian ver. 9.1
  • User interface: Nokia S60 3rd Edition
  • Java: MIDP2.0, CLDC 1.1, 3D API, PIM API, File access API
  • C++ and Java SDKs
Watch New - Media to-go
Stream media files from compatible media portals
RealPlayer media player
  • Stream media files from compatible media portals
  • True Web experience with Nokia Web Browser (secondary browser)
  • RealPlayer media player
  • Download and play multimedia files (video and music)
  • Full-screen video playback on the device to view downloaded, streamed or recorded video clips in larger size
  • Played formats: AMR-NB, AMR-WB, AAC, RealAudio, RealVideo, H.263, MPEG-4
Power management
Operating Times*
  • Talk time (ECTEL): up to 226 min (WCDMA) / 246 min (GSM)
  • Standby time (ECTEL): up to 370 hours (WCDMA) / 350 hours (GSM)
  • Still images : up to 800 pictures (3.2 megapixel)
  • Video capture up to 186 min (CIF, 15fps)
  • Video call up to 150 min
  • Video playback up to 366 min (CIF, 15fps)
  • Music playback up to 12.6 hours (offline mode)
Operation times may vary depending on radio access technology used, operator network configuration and usage.
Contenu du coffret de vente:
Cliquez sur l'image pour l'agrandir.
  • Nokia N73 - coloris: Silver Grey/Deep Plum
  • Nokia Battery BP-6M (1100mAH)
  • Nokia Charger AC-4
  • Nokia Charger Adapter CA-44
  • Nokia Classic Stereo Headset HS-23
  • Nokia Connectivity Cable CA-53
  • Wrist strap and lens cleaning cloth
  • CD-ROM: Nokia PC Suite & Adobe Photoshop Album Starter Edition
  • User Documentation: User guide, Get Started guide, Get Connected guide & Additional Applications leaflet
Le contenu en images :
Voici le Nokia N73 de la gamme Nseries, un vrai concentré technologique dédié à l'image, un vrai APN qui devrait lui aussi être récompensé par la TIPA tout comme le N80.
Quelques images:
Cliquer pour agrandir Cliquer pour agrandir Cliquer pour agrandir
Cliquez sur les images pour les agrandir.
Le Nokia Nseries N73 est vraiment magnifique, le voici en images ce mobile aux formes androgynes en Nseries Family's et S60 Family's too :hug: :
Aspect général:
Les finitions du Nokia Nseries N73 sont quasi "parfaites" dans la lignée des Nseries, de la grâce et de l'élégance mêllée avec sobriété et toujours avec une partie "métalique" au niveau de la finition il est vraiment longi-ligne et son écran est superbe même si la résolution est moindre par rapport au N80, premières petites déceptions, absence d'une carte mémoire dans le coffret, il n'y a plus de chanière pour le hotswap qui a par ailleurs aussi changé de place, il est situé au niveau de la partie inférieur du mobile au dessus de la connectique pop port c'est une petite "tirette" assez rigide mais pas trop quand même que l'on ne peut guère tirer et semble créer quelques difficultés pour désinsérer la MiniSD, c'est un peu court il faut légerement tordre la partie pour y accéder correctement. A l'usage il va falloir être précautionneux et éviter les gestes brusques..
Quelques images:
En ce qui concerne les touches et le clavier ils sont très bien conçus bien que les touches soient peut être légerement trop petites pour une rédaction de texte ultra rapide, le clavier d'une manière générale est très plat, il n'y a pas de reliefs ergonomiques comme sur certains autres modèles.
Voyons cet appareil photo numérique de l'intérieur, oups, pardon, téléphone mobile :) :glurps:
Ecran et interface utilisateur:
Quelques screenshots:
Cliquez sur les les images pour les agrandir
Pas de changements toujours l'interface Symbian S60(Serie 60), presque identique à celle du N80, l'interface revue du N73 est quelque plus dépouillée, simpliste, dans le menu général des dossiers ont disparus et les fonctions regroupées dans un nombre plus restreint de dossiers, les principaux.
Concernant l'écran, il est d'une lisibilité géniale, ces 2,4pouce se ressentent et s'apprécient énormément pour la restitution des images et les caractères sont d'une finesse, c'est très agréable, toujours est il que la protection d'origine est estampillée, peinte par je ne sais quel procédé sérigraphique du sigle "Nokia Nseries", c'est un peu dommage ce gâche toute la lecture de ce si bel écran, je me suis munis de mes protèges écrans habituels je vais très probablement retirer celui d'origine et le remplacer pour profiter de l'écran, mais j'attends car le sigle a l'air de s'en aller naturellement a force de le toucher et un peu de sueur laissé dessus pendant une conversation en plein soleil.
Fonctions multimédias:
L'appareil photo, un capteur CMOS de 3,2MPX, un objectif Carl Zeiss Tessar 2.8/5.6 autofocus font de ce mobile si je puis dire, un vrai petit APN offrant une qualité et une finesse d'image tout-à-fait honnorable,le panel est vraiment très complet mais peut etre finalement pas aussi complet que son prédecesseur le Nokia N80.
En effet quelques paramètres de configurations qui à mes yeux semblaient indispensables pour "sculpter une image en B&W ou couleurs ont disparus au gré d'autres qui ont apparu mais ne permettant pas autant de parametres que son prédecesseur le Nokia N80 qui me semblait plus "complet", ces derniers sont le réglage du contraste, le réglage de la saturation des couleurs ainsi que ceux de la netteté qui se faisaient manuellement pendant la prise de photos sur le N80, à sa décharge sur le N73 sont apparus le réglage ISO, et une nouvelle possibilité de "teinte couleurs" appelée "vives" qui a pour effet d'augmenter la vivacité des couleurs, une sorte de filtre polarisant même si c'est un peu tiré par les cheveux ;) .
Les photos prises sont aussi beaucoup moins lourdes(1,3mo pour la plus lourde pour l'instant) qu'avec le N80 qui lui ne possède pas d'AF probablement la cause de différences de réglages, il manque tout de même le réglage du contraste pendant la prise!
Toujours est il que l'on obtient tout de même de très bon clichés que l'on peut néanmoins remodifier à l'aide de l'éditeur de photos intégré ou le réglage du contraste et de la netteté sont toujours présent, il s'agit la d'un appareil photo numérique entre les mains tant les possibilité d'améliorer les prises de vues sont multiples et c'est plus net qu'avec le N80.
Voici quelques clichés pris avec le Nokia Nseries N73 taille réelle:
Voici un petit test réalisé avec 2 mobiles différents N80 et N73(les photos sont dans cet ordre chronologique) :
1,3mo contre 620Ko :glurps: ..
Video
Voici un screenshot:
Les fonctions sont moins évoluées que celles de l'appareil photo, le mode macro est absent et seuls un mode automatique et nuit assurent les paramètres de configurations vidéo en plus de la balances des blancs ainsi que les teintes de couleurs, en revanche la qualité d'enregistrement vidéo est quand même un peu mieux que celle du N80 si j'ai un peu de temps je ferais le test pour que l'on puisse vérifier, il est possible aussi de modifier la vidéo et d'ailleurs les menus d'options sont légèrement différents de ceux du N80.
A titre indiquatif une vidéo réalisé avec le Nokia N73 dont voici le lien direct:
-->Video Nokia N73 by anakronik
Voici un petit comparatif qualité d'enregistrement vidéo entre le N73 et le N80:
-->Vidéo filmé avec le Nokia N73
-->Vidéo filmé avec le Nokia N80
Peut être qu'un éventuel upgrade du firmware améliorera la qualité vidéo qui pourrait être un poil meilleure.
Divertissements
Pour le lecteur audio il est identique à celui du Nokia N80, présence d'un égaliseur avec différentes sonorités programmables, les menus contextuels sont aussi les mêmes, en ce qui concerne l'écoute, les HP(haut paleur) ou j'ai bien dis LES car il y en a deux c'est LA grande nouveauté en plus de l'objectif AF Carl Zeiss, un situé sur la partie supérieur du mobile et l'autre sur la partie inférieur sous la connectique Pop Port la qualité d'écoute est carrément mieux que sur le N80 que ce soit avec un casque ou via le HP grâce aussi aux effets 3D pour les sonneries.
Un jeu est présent Snake mais heureusement comparé au N80 d'autres jeux ont vu le jour depuis, ils est possible d'en installer d'autres sous formes de fichiers Symbian(.sis) ou JAVA(.jar).
Concernant RealPlayer pas de changements non plus toujours aussi simple d'utilisation avec ses raccourcis pour pouvoir visionner, avancer, reculer sur un fichier vidéo.
Sonneries effet 3D, navigateur internet et autres
La nouvelle fonction qui fait son apparition pour les S60 Nokia, les sonneries avec un effet 3D, gérer par une application complètement dédiée et très bien rediffusé grâce aux deux HP stéréo, les paramètres sont vraiment géniaux.Concernant ces connectivités comparées au N80 la regrettable absence d'une connexion WIFI qui fait donc toujours du N80 un des "Must" en matière de combinés multimédia néanmoins la connectivité BT 2.0, USB, IRDA et 3G font de ceux mobile un appareil très complet et totalement autonome.
Voila dans les grandes lignes les fonctions de cet élégant Nokia Nseries N80, pour terminer afin de vous divertir comme la dernière fois j'ai enregistré une petite vidéo que j'ai humblement réalisé, ce petit clip dure douze ou treize de minutes au format .WMV :) .
vous verez en live plusieurs des fonctions citées ci au cours de ce review.
Les musiques de fonds proviennent du N73 ;)
Voici le lien direct:
-->Démonstration vidéo du N73 by anakronik
Conclusion :
Un "PS"(Photo-Smartphone) vraiment magnifique à posséder absolument pour les amoureux et passionnés de photos avec son design "Candy Bar" ou appelé monobloc, son protège APN, avec des fonctions multimédias vraiment à la hauteur de tous espoirs en matière de technologie mobile.
La mobilité ets vraiment au rendez vous avec le Nokia N73 ayant une meilleur accroche réseau que le N80, un emeilleur autonomie, une bonne réception, un APN tri-mégapixel avec objectif Carl Zeiss, un mode macro, un port USB, le bluetooth 2.0, l'IRDA et toutes ses autres fonctions.
Simple d'utilisation, agréable en mains et ses lignes quelques peut féminines le Nokia N73 satisfera les professionnelles ou le simple usage particulier, fonction walkman de poche accueillant une MiniSD de 2GO, suffisant pour y mettre quelques albums de musiques, films et photos.
Les "plus" :
  • 3,2MP mode macro
  • Objectif Carl Zeiss Tessar
  • Cache APN
  • Connectivités : 3G, USB, Bluetooth 2.0, IRDA
  • Sonnerie effet 3D
  • Symbian OSv9.1
  • Autonomie
  • Taille de l'écran 2,4pouce
  • Résolution de l'écran 240 x 320 pixels (262 114 couleurs)
  • Capacité mémoire: 45mo interne
  • Hot Swap MiniSD extensible
  • Mode économie de la batterie
  • Lecteur pourvu d'un égaliseur
  • Fonctions multimédias
  • Ergonomie et simplicité d'utilisation
Les "moins" :
  • Carte mémoire non fourrnie
  • Absence du WIFI
  • Cache du HotSwap fragile
  • Difficulté du retrait de la carte
  • 1 seul jeu fourni
  • Qualité vidéo
  • Absence du réglage du contraste
  • Commande du volume impossible avec le joystick
  • Déclenchement impossible d'une vidéo/une photo via le joystick
Quick links :
On FM board :
-->[N73] Discussion
-->[N73] Remarques, impressions après achat
-->[Symbian 9.1] Logiciels, applications, jeux
-->[6270, 6280, N71, N80, N73, N93] MiniSD
On the Web
-->www.nseries.com
-->Manuel PDF en anglais
-->Galerie photos consacrée au Nokia N73
Fly me to the moon
FlickR
#2 romsac
romsac
  • 2251 messages
  • Modèle:3gs 32w
Posté 10 Aug 2006 - 23:30
Merci pour ce beau test :glurps:
Iphone 4s 64 black + origami star 2h
#3 Fanne
Fanne
    il fut un temps
  • 2845 messages
  • Modèle:W900i
Posté 10 Aug 2006 - 23:39
Pas mal la présentation ( les photos ) de l'aspect du portable , ça fait pro !
#4 Evi
Evi
  • 1295 messages
  • Sexe:Féminin
  • Modèle:x820
Posté 10 Aug 2006 - 23:44
Excellent test bien travaillé, complet, bref un plaisir à lire.
Merci Anakronik et encore bravo.
#5 Dr.Destin
Dr.Destin
  • 573 messages
  • Mobile:LG
  • Modèle:Optimus 2X
  • Opérateur:CH Swisscom
Posté 10 Aug 2006 - 23:49
arf deja que j'ai envie de ce portable et que je peu pas l'acheter j'ai fait l'erreur d'aller voir ton Test SUPERBE!!!!!!!maintenant je suis jalou :glurps: ;) :hug:
en faite l'ecriture Nserie blanche sa provient de l'ecran ou c'est un plastique posé dessu?
Edit: je vien de voir la video c'est un plastique posé dessus il aurai pu faire quelque chose de moin genant comme protége ecran :glurps:
Modifié par raph654, 10 Aug 2006 - 23:54.
Ancien pseudo "raph654"
#6 mancantgite
mancantgite
  • 528 messages
  • Modèle:N85
Posté 11 Aug 2006 - 00:06
Merçi pour ce test anakronik , du tres beau Boulot comme d'habitude :)
IPHONE 3G
HTC HD2
Forfait VirginMobile SL Paradyse 2H d'appels + 5 Numéros illimités tt operateurs, sms, internet, push mail et messenger illimités 24h/24 7j/7 ( 31,90€ sans engagement :))
Bientôt mon IPHONE 4 inchallah !!!!!!! :)
#7 GUIGOZ
GUIGOZ
  • 467 messages
Posté 11 Aug 2006 - 00:07
Merci pour cet excellent test Anakronik :)
Vraiment bien ce N73 la finition a l'air vraiment excellente :)
mais c'est vraiment dommage qu'il n'ait pas le wifi sinon il serait déjà mien :( C'est son gros défaut pour moi. (un des seul qu'il ait)
N8 Dark Grey 16Gb
N93 Pearl Black + Transcend 80x 2Gb + Tomtom 6 + Holux GR-230
N80 Pearl Black Internet Edition + Tomtom 6 + Holux GR-230
N70 + Kingston 512 + Tomtom + Holux GR-230
#8 Anakronik
Anakronik
  • 11143 messages
  • Modèle:S60 User
Posté 11 Aug 2006 - 00:21
Bonsoir :)
Merci a tous cela fait plaisir :(
La prochaine les photos seront prises avec un 350D je l'ai eu aujourd'hui et ne le maitrise pas encore assez du coup j'ai utilisé mon DCR-PC9 pour faire les photos..
C'est vrai qu'il est très esthétique, agréable au toucher, il est vraiment bien fini, le cache APN est super rigide au niveau du glissement, pas de jeu au niveau de la coque ni sur les touches.
Il ne manque que le WIFI c'est bien dommage mais bon tu as tjs la solution d'avoir les deux :) ..
Fly me to the moon
FlickR
#9 eljoundi
eljoundi
    FM Addict
  • 2363 messages
  • Modèle:E71
Posté 11 Aug 2006 - 01:50
Merci anakronik pour le test :)
je n'ai connu ce portable que ce matin en lisant un sujet dessus, et te voilà en possession de ce bijou :)
Je pense que ça sera mon prochain mobiles, le remplaçant de mon vieux 6630 :)
HS : pas mal le 350D :( , vivement les photos prises avec ce reflex de grande qualité
-- En cours --
#10 Alfred
Alfred
    Consultant FM
  • 8315 messages
  • Modèle:Galaxy S4
Posté 11 Aug 2006 - 06:13
Félicitations anakronik, beau boulot, beau produit aussi faut dire ! :)
#11 Kamiyadori
Kamiyadori
    PS3 User
  • 3254 messages
  • Modèle:Z5 Gold
Posté 11 Aug 2006 - 07:39
Beau boulot effectivement!!! :)
Encore un beau Nokia, mais c'est un candybar! Donc pas pour moi! Mais je vois une inspiration du N91 pour toutes les parties chromées!
Modifié par Kameo Dark, 11 Aug 2006 - 07:39.
#12 Sinklar
Sinklar
    — Texas Ranger —
  • 5322 messages
Posté 11 Aug 2006 - 09:10
Pffiou... ça c'est du test. Digne des pros. Bravo pour les moyens mis en oeuvre. Rien que le test en lui-même donnerait envie de l'avoir.
LE N73 prend de très beaux clichés soit dit en passant.
"Hé les gars, prenez-en de la graine" (a) (humour)
#13 Surfer77
Surfer77
  • 7937 messages
  • Modèle:4G & 4GS
Posté 11 Aug 2006 - 09:53
Super beau test comme d'hab Anak! (a) :)
Il donne envie!
(a)
#14 Anakronik
Anakronik
  • 11143 messages
  • Modèle:S60 User
Posté 11 Aug 2006 - 10:12
Yep merci (a)
C'est bien ce que je voulais, faire envie (a) :)
L'estampille Nokia Nseries peinte ou sérigraphiée sur le protège écran a complètement disparue je peu profiter enfin de l'écran sans meme changer de film protecteur :)
Fly me to the moon
FlickR
#15 -= Naillik =-
-= Naillik =-
  • 3187 messages
  • Modèle:T650i
  • Opérateur:CH Orange
Posté 11 Aug 2006 - 10:32
Merci pour ce beau test!! (a)
Il y aura une personne qui sera super content de ce test.... floflo(a)
PS: La qualité de la vidéo est assez triste je trouve... :)
#16 Anakronik
Anakronik
  • 11143 messages
  • Modèle:S60 User
Posté 11 Aug 2006 - 10:38
Concernant la vidéo comme vous pouvez le constater l'utilisation du zoom ne vaut vraiment pas le coup, mieux vaut l'utiliser sans, a ce moment la qualité est plus ou moins correcte un poil mieux que celle du n80, mais cela y fait aussi grace a l'objectif qui est plus lumineux que le N80 (a)
Fly me to the moon
FlickR
#17 floflo57100
floflo57100
    Floflo d'FM
  • 4602 messages
Posté 11 Aug 2006 - 10:40
Bravo pour ce magnifique test Anak'! :) En passant, magnifique mobile d'ailleurs! :) Qui sera mien bientôt! (a) :) J'suis encore plus pressé de l'avoir maintenant après avoir lu ton test! (a)
Tres bon boulot! :)
#18 Jpack
Jpack
    InsOm-nIaK
  • 3262 messages
  • Modèle:Iphone 3GS
Posté 11 Aug 2006 - 11:02
Super test Anak'
Nokia a encore tenu ses promesses d'après ce que je vois!
#19 Dr.Destin
Dr.Destin
  • 573 messages
  • Mobile:LG
  • Modèle:Optimus 2X
Posté 11 Aug 2006 - 11:21
Yep merci :)
C'est bien ce que je voulais, faire envie :top: ;)
bon bah hereusement que sa part :) :top:
#20 Oxygo
Oxygo
  • 4891 messages
  • Modèle:iPhone 5
Posté 11 Aug 2006 - 11:54
tres beau test ! merci anakronik :top:
