Je créé donc ce nouveau topic pour en discuter et donner nos impressions.
Voici les détails : (merci à Philthewebsurfer )
RM-92 dp v 13.0 (MCU SW 4.0623.0.41)
Date: 17.08.2006 Size: 101.5 MB
- New features
- When there is a headset connected then it is possible to close the slide
without ending the call
- Support for Microsoft Windows Media Player 10 has been added (No
support for DRM)
- Adobe PDF Reader has been added
- Mobile Search has been added
- Antivirus has been added
- FOTA (Firmware Over The Air) pull is enabled in some variants
- Backup
- Backup cannot read midlet when midlet is running before backup starts
- Contacts database is in use if client remains open during
backup/restore
- Java midlet data is not restored
- Panics if java hash information was not parsed successfully
- SIS files are not restored after backup/restore
- Midlets installed to drive other than (C not backed up or restored
- Package data file restoration problem when directory doesn't already
exist
- Backup/Restore failed to restore assigned Speed Dial numbers
- Bluetooth
- Improvements to stability of long term connections
- Switching on BT On ->off-> on can cause phone menu to lock up and
Disappear
- Browser
- Browser memory usage reduction when browsing many sites
- WAP Push correction for CSL
- Remove anti-aliasing for Chinese fonts
- www.kauppalehti.fi login causes connection timed out
- Stop browser loading images when memory low
- Calendar
- Meeting end date does not span correctly if user changes device
timezone to greater than current value
- Received recurring vCal entry is not saved to calendar
- Calendar alarm time imported incorrectly from S40 device
- Calendar editor erases subject field if you edit a full subject field
- Calendar crashes when changing repeat rule on an entry
- The anniversary alarm never goes off
- 100 consecutive alarms does not alert
- Due date and start date are mixed in ToDo items -> ToDo alarm can
not be stopped
- Calendar Options->Delete entry->All entries fails to delete exceptions
to recurring meetings.
- Change in time zone results in incorrect alarm date.
- System error and product freezes with certain Calendar note
- Lunar Calendar information is not available for dates before 1980
- Last instance of repeating meeting is lost, if repeating meeting is
modified in Outlook
- Unable to dismiss calendar alarm
- Repeating calendar entries
- Call
- Manual network selection freezes the phone if there is active PDP
context
- Display wrong operator name "1" in Manual Selection list
- Camera
- Bitmap corruption in thumbnails
- Camera localisation error fix (Localised Slovak) Camera: Wrong
grammar form of Automatic used in Scene Set-up
- Contacts
- Backslash character not properly handled when contact is copied to
memory card
- Data
- Call Back Access Point does not call back
- Rare Stability problems in TCP/IP
- Device Manager
- Display FOTA help for FOTA enabled variants
- Gallery
- Certain animated Gif files do not play when opened from Images and
Videos folder
- Screen becomes black for a second right after playing video file saved
in memory card
- Wrong Presentation icon is shown in the Gallery.
- BT Image Print - Phone is stuck at Cancelling screen
- PictBridge/HP475 - Phone hangs at cancelling screen after cancelling a
pictbridge print job on HP475 printer
- Video file is not played if opening from File Manager while another is
paused on the background.
- DRM image can't be zoomed in if the last right is in use.
- The display position of AnimatedGIF file is incorrect.
- New Camera Images do not appear in Gallery if Gallery is open
- The Animated GIF file, which has copyright protection of valid
Consumable Rights(count=5) can be played more than 5 times.
- 3gp playback incorrect when there are many images on memory card
- No help topics available in Music Settings View.
- Issues with recognizing new mimetypes
- Localisation
- Fallback when help directory is empty
- Memory Card
- Improve FAT mount performance by increasing FAT cache granularity
- Particular 256MB MiniSD card gives "Windows was unable to complete
the format" when formatting under WinXP.
- Memory card unlocking does not work if no card inserted while phone
booted
- Fix for memory card missing on soft reset
- Messaging
- Forwarded attachments visible as unsupported files in attachments
view
- Envelope icon doesn't stop blinking until phone is rebooted
- E-mail : It takes too long to attach contacts via e-mail.
- Message stays in outbox (until rebooted) after cancelling infrared
transmission
- Fixes MMS postcard image import size issue
- Obex crash with corrupted obex header
- Extra space at end of word when typing '/' character
- Can't receive message when using China Unicon dual mode card
- Add any file type to email attachment options
- Incorrect number is shown in note when fetching emails
- IMAP: Crash after trying to retrieve an email when there's no network
coverage
- Message Viewer takes 39 seconds to display long unicode message
- Link Highlight in automatic find does not wrap to next line in mixed
URL/number
- Data cannot be shown and deleted when save a large vCard which
received by IrDA.
- Multimedia
- Progressive JPEG codec doesn't compress heap after decoding
- Music Player
- Music player will be terminated forcefully at the time of selecting
searched data when the [Mark all]selected in track list creation.
- Networking
- Sending many UDP packets results in not all packets reaching the
recipient.
- Real Player
- Large chunk video break up
- Unresponsive RealPlayer after streaming
- Security
- No post after user cancel JAR download
- Exes are launched by Installer App before EULA is accepted
- Installer crashes when uninstalling software
- App. installed in other phone to memory card, shortcut to it is shown in
test phone
- Reset loop with certain (filesystem partly corrupted) MiniSD card
- Application Manager: Application loses list of installed applications
- Syncronisation
- Session ID in server notification (package #0) is not taken into use by
DM client
- Synchronisation fails if entering more than 2 entries in Calendar of the
handset with synchronisation setting as "None"
- UPnP
- Unknown authorisation request causes media server crash.
- UPnP - Apps Menu path in message for creating WLAN access points
is incorrect - localisation of path for all languages.
- Middle ok button does not work in result window
- Copying files with '&' character in
- Home Network, fix for Music playlist sharing selections not working
- USB
- Mass Storage failure. Bulk Transport handles case badly
- USB mass storage class doesn't detach from Apple MAC/Tiger
- Video Telephony
- UE carried no sound or image after the following procedure UE
became out-of-coverage during VT communication. Then it originated
VT after the VT disconnection.
The following changes were also included in SW release 3.0618.0.1 which
was only available in some markets.
- Call
- DTMF tones now allowed for emergency call created with locked phone
- Applications
- RealPlayer updated – Improved handling for large chunk video
break up
- RealPlayer updated – Improvements to unresponsive RealPlayer
after streaming
- Settings
- Settings wizard updated to week 16 release for Taiwan country
Settings
- SIM
- Correction to SAT polling reponse
- Accessories
- Connecting doesn't succeed after disconnecting N616 car kit and
from 3G to 2G
- AD15 in Music Player mode has poor sound quality (until volume
changed)
